Thread: Licensing for Terminal Server
    02.09.2013
    Default Licensing for Terminal Server
    I have a one wibu-key USB dongle for development, runtime, webserver, and all drivers for Energy Edition.
    If I register Zenon (7.11) as "Standard", license work as a charm.
    If insted I register Zenon as "Terminal Server" in the licensing tool it doesn't work anymore and I can use only the Demo mode.
    I took a look to the documentation but I couldn't find a solution. Do I need a "Network dongle"? What can I do to license my Server as "Terminal Server"? I can use the same dongle, can't I?
    Thank you
    Alberto Di Vittorio
    louis.paglaiccetti Gast
    Default Re: Licensing for Terminal Server
    Hi Alberto,
    Yes, on the terminal server, you do need a network dongle with licenses booked for concurrent runtime users.
    And keep in mind, this is not possible for the development/zenon Editor.
    Are you using Microsoft Windows Server, with Remote Desktop Services? Are you sure that has been properly configured? A good test to check for a proper configuration, try to first see if a small standalone .exe application (notepad.exe) works via Remote Desktop Services.
  1. Zenon Runtime / Terminal Server
    By kfn3000 in forum zenon Network
    Last Post: 23rd December 2015, 17:30
  2. Replies: 0
    Last Post: 16th January 2014, 20:45
  3. Runtime am Terminal Server
    By kwb in forum Editor and Runtime Setup
    Last Post: 20th August 2013, 09:17
  4. Licensing problem
    By shikra in forum Editor and Runtime Setup
    Last Post: 30th November 2009, 06:29
  5. Runtime über Terminal Server
    By kwb in forum zenon Network
    Last Post: 31st July 2009, 11:22
