Thread: Number of not Acknowledged Alarms
    20.08.2014
    13
    Default Number of not Acknowledged Alarms
    Dear specialists,
    could you advice me how to write number of not acknowledged alarms into variable. I found that it is possible to get this parameter from the SYSDRV driver using system variable "Alarms not acknowledged". But the question is, how to get number of not acknowledged alarms of chosen class/group/area?
    18.07.2011
    138
    Default AW: Number of not Acknowledged Alarms
    Dear Kateryna.
    Alarm groups/classes do differ from alarm areas. The way to go is to define your alarm classes and link them to an alarm area then. In the alarm areas properties you will find the Class linking. If you link an alarm class you can define variables for the number of active alarms and for the number of unacknowledged alarms within that particular alarm class.
    Don't forget to link the alarm area in the variables alarm handling properties then.
    best regards,
    Johannes
    20.08.2014
    13
    Default Re: AW: Number of not Acknowledged Alarms
    Thank you johannes.foidl for answer. Your solution is working for this task.Many many thanks ))
    20.08.2014
    13
    Default Re: Number of not Acknowledged Alarms
    Dear specialists,
    I'm trying to solve the same problem with only one difference, what I need is to find out the number of unacknowledged alarms from the one specific class and area and place this number to the variable.
    This number increments each time when the new alarm comes. But the problem is, when the new alarm comes and then goes before I'm able to acknowledge it and then I acknowledge it (as an alarm which is gone) the number of unacknowledged alarms doesn't decrement back. To rephrase, the number of unacknowledged alarms stay the same even if alarm has already gone and then been acknowledged.
    If I acknowledge alarm before it's gone the number of unacknowledged alarm decrease as expected.
    Please, could anyone explain why number of unacknowledged alarms depends on sequence of acknowledgment based on when the alarm leave.
  1. Number of Alarms.
    Last Post: 20th December 2013, 12:30
  2. Variables Number Exceeded
    Last Post: 29th June 2009, 11:05
  3. number of alarms
    Last Post: 25th June 2009, 05:33
  4. First Un Acknowledged alarm
    By nahala in forum zenon Supervisor
    Last Post: 3rd May 2009, 17:14
  5. How to check if an alarm is acknowledged or not?
    Last Post: 6th August 2008, 15:18
