Thread: adjustzenonvalue
    29.09.2011
    Default adjustzenonvalue
    I'd like to ask if you could give me a sample of how to program the adjustzenonvalue macro?I'm not that familiar with VBA but I'd like to use it for one of our projects.
    thanks
    11.06.2013
    32
    Default Re: adjustzenonvalue
    Hi figuerra!
    Iím not sure, if I could understand your question correctly. But maybe the following link could help you.
    Best whishes
    28.06.2013
    21
    Default AW: adjustzenonvalue
    Quote Originally Posted by figuerra View Post
    thanks
    you have to create the AdJustZenOnValue with your Macorlist.
    Heres an example for the Macro:
    Public Function AdjustZenOnValue_BCD(obVar As Variable, vValue As Variant) As Double
    On Error Resume Next
    Dim W As Variant
    'Diese Function wandelt z.B. einen Sollwert in den BCD Code um,
    'damit dieser korrekt in die Steuerung abgesetzt werden kann
        W = vValue
        AdjustZenOnValue_BCD = W / 10
    End Function
    Put this non-linear value adjustment on your Variable you want to edit.
    On each Change the value of the variable this Macro will activate.
    For example your PLC gets the value 10 you divide this value by 10 and your variable has the value 1.
