Thread: Missing Motors in FieldbusKonfig of zenon logic for EV3
    18.08.2011
    6
    Default Missing Motors in FieldbusKonfig of zenon logic for EV3
    By adding the EV3 Controller, i did not get the drive ports!
    This is how the config tree looks like:
    LEGO EV3
    - EV3 - Buttons
    - Sensoren - Port 0 .. 3
    There are no drive ports!!!
    When i add the NXT Controller, it looks like this:
    LEGO Mindstorm NXT 2.0
    - NXT - Status
    - Motoren - Port A .. C
    - Sensoren - Port 1 .. 4
    So, what is wrong? Or is there a other way to insert the drives?
    18.08.2011
    6
    Default Re: Missing Motors in FieldbusKonfig of zenon logic for EV3
    ok - everything is clear now!!!
    11.06.2013
    32
    Hi marcel.widmer,
    great to hear!
    Please, could you share your solution to the “CopaData Forum – Community”?
    Thank you and best wishes
    13.01.2015
    8
    Can you explain me what you did to solve the problem?
    Thank you.
    07.02.2015
    Default AW: Missing Motors in FieldbusKonfig of zenon logic for EV3
    That#s intersting me too
    17.12.2014
    4
    Hi guys,
    if you are using the EV3 Brick the Drives wont be displayed in the fieldbus configuration.
    You have to control the drives directly, for example, via function blocks. I attached a Screenshot where you see the right function blocks.
    David.Schwarzl posted a good how-to guide here: (2nd post in this Thread)
    http://www.copadata.com/forums/showthread.php?t=2928
    Best Regards
    Philip
  1. zenon logic doesn't communicate with external variables in zenon
  2. Re: zenon logic doesn't communicate with external variables in zenon
  3. Zenon Logic sample program for EV3 needed
    By dimi in forum straton / zenon Logic
    Last Post: 10th July 2014, 10:23
  4. Zenon logic
    By sidramsatyal in forum straton / zenon Logic
    Last Post: 1st July 2014, 09:45
