Thread: Hardware Requirements (General)
    04.09.2009
    84
    Default Hardware Requirements (General)
    Hello Support,
    Assume we have 7000 tags, 6000 are Modbus TCP tags and 1000 belong to Math variable type. Further assume that we have around 500 screen switch functions and few allocations ( lets say 10)
    What should be the minimum hardware parameters to smoothly run Zenon Runtime having above configuration. A quad core 1.7 GHz processor having 8 Gb RAM will suffice ?
    Regards.
    louis.paglaiccetti Gast
    Default Re: Hardware Requirements (General)
    Hello Shikra,
    Thanks for your post.
    First, I would suggest you have a look in the documentation:
    Manual -> Installation and updates -> System requirements -> Hardware requirements
    As a personal comment: with typical and reasonable configurations, I think this hardware should have no problems with a project like this. However, since zenon is so flexible, much of it comes down to how this project is configured. There are definitely some strategies you can pick-up in a basic zenon training about recommenced ways to engineer the HMI/SCADA project, best practices, etc. Topics like utilizing multiple driver instances, offloading complex or heavy calculations to the zenon Logic IEC 61131-3 soft PLC engine, etc., etc.etc.
    I see nothing wrong with these number, but if you are in-doubt, contact your local copa-data support team for guidance.
  1. General question of names
    By sue in forum Off Topic
    Last Post: 30th March 2018, 06:12
  2. General Report
    By natali in forum zenon Supervisor
    Last Post: 19th February 2013, 15:39
  3. Send Value to hardware
    By anahita in forum VBA
    Last Post: 7th August 2011, 22:54
  4. what is the minimum system requirements of your ZenOn products?
    By lephis in forum Editor and Runtime Setup
    Last Post: 8th February 2010, 08:27
