Thread: Dual Ethernet Port in Runtime PC
    22.07.2014
    2
    Default Dual Ethernet Port in Runtime PC
    Hi Support,
    I am using zenon V7.11. I have zenon runtime running in PC with dual ethernet ports. Those ports are connected into the same hub. Everything is running well, but when the primary ethernet cable (primary port) is disconnected, the runtime is also stopped.
    Is there anyway to create a backup connection using the secondary ethernet cable (secondary port)? So when the primary cable is disconnected, runtime is still running using the secondary ethernet cable. What should i do to create that kind of system?
    Any help will be greatly appreciated. Thanks.
    24.07.2008
    89
    Default AW: Dual Ethernet Port in Runtime PC
    Hi andrigunawan,
    how are the IP-addresses assigned? Static or dynamic? Is the name resolution working?
    "Everything is running well, but when the primary ethernet cable (primary port) is disconnected, the runtime is also stopped. "
    Normally the runtime should not stop automatically, if you unplug the network cable.
    Are u using the zenon Redundancy Management Tool - for closing the RT?
    Basically zenon network requires a working name resolution.
    The runtime doesn't care if it uses the first network card or the second one.
    22.07.2014
    2
    Default Re: AW: Dual Ethernet Port in Runtime PC
    Hi konstantif,
    Sorry for late reply and thanks for your response. I already used default feature (may be) from windows. This feature can combine 2 IP addresses into single (virtual) IP address. If one of those IP Addresses is going down, another IP Address can back it up. So, i think my problem is solved
    Thanks for your help
  1. Replies: 9
    Last Post: 22nd April 2014, 08:26
  2. ZENON-Dual Redundant Server
    Last Post: 5th May 2010, 10:03
  3. Ethernet IP Communication
    By amolck in forum straton / zenon Logic
    Last Post: 15th March 2010, 06:11
  4. Problem with dual monitor system
    By tulon in forum zenon Supervisor
    Last Post: 31st March 2009, 08:22
  5. Diagnosis server TCP port 1101 is already used
    Last Post: 22nd July 2008, 08:00
