Thread: Latest AddOn for the zenon Science Package
    04.11.2013
    11
    Lächeln Latest AddOn for the zenon Science Package
    Hello everybody,
    the latest AddOn for the EV3 Science Package is available.
    This update resolves the following issues:
    1. Wi-Fi connection problem
    2. Problem with the SINT data type
    3. Problem with color- and infrared sensor (an old issue is still there: if there is one or several UART sensor(s) connected, when the application is stopped (via the Logic workbench or via downloading a new application) and then is restarted, sometimes, the first UART sensor gets an error.
    The workaround is to stop the runtime on the Lego and restart it.)
    If you have already installed the zenon Science Package 7.11:
    Execute the attached AddOn.
    Choose "Maintain or update" option.
    Next, choose the "Repair" option and the files will be reinstalled.
    The new runtime files for the EV3 brick are located in the folder where the science package was installed. The folder is named "T5RT".
    How to update the runtime on the brick is written in the tutorial.
    If you haven't installed the zenon Science Package 7.11:
    First, install the Science Package. Next, proceed like in the steps above.
    You can find the ISO-file here: http://www.copadata.com/forums/showthread.php?t=2962
    Important: The updates are not included in the setup. You have to install the AddOn too.
    David
    12.08.2014
    14
    Default Re: Latest AddOn for the zenon Science Package
    Hello
    I've installed the AddOn as you've described. The new Runtime is also installed.
    If i use the color sensor, it is still blinking red. I also removed the other sensors. but it wont work.
    Does it work by other people?
    petzi91 Gast
    Default AW: Re: Latest AddOn for the zenon Science Package
    Hello arueger,
    I have the same problem!
    Best regards
    Timo
    12.08.2014
    14
    I've the soution.
    You need to change the fielbus.
    You now have the EV3 Color Sensor, wich you have to chosses.
    I've done a screenshot for you.
    Attached Thumbnails Attached Thumbnails Screen Shot 09-16-14 at 10.05 AM.PNG
  1. Installing science package
    By mightor in forum Editor and Runtime Setup
    Last Post: 5th February 2012, 10:54
