Thread: Zenon v7.11 SP0 Build10238 32Bit to 64Bit
    08.12.2013
    27
    Default Zenon v7.11 SP0 Build10238 32Bit to 64Bit
    Can I backup project from 32bit Zenon and restore project in 64bit Zenon?
    Any step needed to change the configuration or settings?
    Any precaution?
    Thanks!
    27.06.2011
    96
    Default AW: Zenon v7.11 SP0 Build10238 32Bit to 64Bit
    hi,
    you donīt even have to create a backup and restore it in the other version. Both access the same database. So you can easily load any project in 32 and 64 bit versions.
    regards
    08.12.2013
    27
    Default Re: AW: Zenon v7.11 SP0 Build10238 32Bit to 64Bit
    Hi Alex,
    Because I need to transfer to different server, so backup is needed.
    Any precaution needed to take? Or it is no issue at all to transfer between 32bit to 64bit?
    27.06.2011
    96
    hi yitlilee,
    there should be no issues. Simply load the backup in the 64bit editor and it will work fine.
    regards,
    Alex
    08.12.2013
    27
    Thanks Alex!
  1. Zenon 7.00 SP0 build4
    By xeren in forum Engineering Studio & Service Engine
    Last Post: 6th June 2017, 08:00
  2. Fehlt zenOn 64bit auf der 7.10 DVD?
    By hp in forum Engineering Studio & Service Engine
    Last Post: 2nd May 2013, 09:07
  3. zenon 6.5 sp0 for windows 7 professional 64bit
    Last Post: 1st November 2011, 23:07
  4. Zenon 6.50 Sp0 build 1 warning
    Last Post: 11th August 2010, 08:19
