Thread: Restore Deleted Project
    08.12.2013
    27
    Default Restore Deleted Project
    Need a favor from you, how can I restore/retrieve project without project backup file? i've accidentally deleted project from workspace without backup, is that possible to restore the project? Urgent, thanks!
    27.06.2011
    96
    Default AW: Restore Deleted Project
    hello yitilee,
    did you remove the project from the workspace, or did you really delete it. These are two different things! If you have just removed it, then you can opent the workspace´s context menu and select "add existing project". In the list you will then find your project. If you, however, deleted the project, then I´m afraid, there is no way to get it back.
    regards,
    Alex
    08.12.2013
    27
    Default Re: AW: Restore Deleted Project
    Hi Alex,
    Yes, project deleted from workspace, not shown in "insert existing project".
    No mirror or temporary backup file for project?
    27.06.2011
    96
    I´m afraid there´s no way to get it back :-(
    08.12.2013
    27
    Ok, too bad, but anyway thanks Alex
  1. License Utility got deleted
    By nvishnuteja in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 1st August 2014, 10:07
  2. Restore Project Backup
    By yara in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 4th December 2013, 11:11
  3. Problem of VSTA after restore project
    By altera in forum VSTA
    Last Post: 22nd June 2010, 14:48
  4. Restore project from SQL Database Folder
    By bernhardf in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 13th October 2009, 09:07
  5. Restore deleted links in elements
    By sebastiank in forum VBA
    Last Post: 28th August 2007, 09:58
