Thread: Message control - SMTP
    Default Message control - SMTP
    Hi support team,
    I am trying to send message through zenon 7.0 to my gmail account.
    I enabled the pop in my mail settings & did the configurations in zenon.
    created functions send message and message activate.
    defined user.
    Please find the attached snaps.
    I am not able to receive mails in my mail account.
    In zenon diagnosis viewer it says creating SSL/TSL method failed.
    Please tell me if i am wrong in configurations
    Thanks in advance.
    louis.paglaiccetti Gast
    Default Re: Message control - SMTP
    Hello jahidbagwan,
    I have attached a sample screenshot that works when sending SMTP mails from zenon 7.11 by using gmail for example.
    Thanks,
    Lou
    Hello jahidbagwan,
    In summary, give it a try if you activate (check) the option "Use APOP for authentication".
    Thanks,
    Lou
    a.oprean Gast
    I did the configurations in zenon as in the example above, and I also enabled pop in my email settings, but I am getting the next error: APOP Authentication is required but the Server did not send APOP Data.
    What am I doing wrong?
    Thank you!
    martins Gast
    Default AW: Message control - SMTP
    hi,
    best idea is maybe to look up if there is some documentation from your e-mail provider how to configure e.g. Outlook or Windows Mail for receiving and sending mails. In general, the settings are name pretty much the same in Outlook and in zenon so it should be easy then to link this information to how to configure SMTP in zenon.
    For some more well known providers, there is a list on the internet (unfortunately in German, but you should still be able to understand some information): http://www.patshaping.de/hilfen_ta/pop3_smtp.htm
    Otherwise, you could also tell us your provider and we could help you search for the right configuration
    best regards,
    Martin
  1. Message control
    By ziadnajjar in forum zenon Network
    Last Post: 24th June 2014, 07:33
  2. Message Control
    By navaneet in forum zenon Network
    Last Post: 2nd May 2014, 12:00
  3. Replies: 2
    Last Post: 25th January 2013, 13:25
  4. Replies: 0
  5. Replies: 0
