Thread: Re: zenon logic doesn't communicate with external variables in zenon
    Default Re: zenon logic doesn't communicate with external variables in zenon
    I am using zenon to communicate with Beckhoff PLC. I am able to communicate plc driver variables between the two. Can you please advise me how zenon system variables can be communicated to the PLC.
    Many thanks in advance!
    Hi anjali.gk.nair,
    You could create an allocation in the editor and link as the source variable the system driver variable and a beckhoff PLC variable as the target variable.
    When the system driver variable changes, the PLC variable will be written.
    Thank you very much Mark!
  1. zenon logic doesn't communicate with external variables in zenon
  2. Zenon logic
    By sidramsatyal in forum straton / zenon Logic
    Last Post: 1st July 2014, 09:45
  3. Minimal external variable change interval to be hooked in zenOn
    Last Post: 24th September 2013, 18:38
  4. External IEC 60850 variables names not recognised in ZenonLogic
    By djgaunt in forum straton / zenon Logic
    Last Post: 12th August 2013, 07:53
  5. Zenon Logic Redundancy
    By davide.galigani in forum straton / zenon Logic
    Last Post: 24th April 2013, 07:22
