Thread: Functionalities of ALARM-blocks in Logic
    Frage Functionalities of ALARM-blocks in Logic
    Hi!
    I tried to use block ALARM_M in Zenon Logic. How does it connect with alarm in main project? How can I create limit text?
    Here is my testing FB-shema.
    Regards.
    816
    Default Re: Functionalities of ALARM-blocks in Logic
    do you want to produce alarm with always the same text or different texts depending on some process value?
    Typically when the output Q of the FB is true then you can change value of some variable. For example when you have a STRING variable for alarm text you can program following (ST language, 'xxx' are names not visible on your screenshot):
    if alarm_sktp_xxx.Q then
    var_alarm_text := 'alarm is trigged';
    else
    var_alarm_text := '';
    end_if;
    This string variable you can communicate via stratonNG driver to zenon and make a AML or CEL entry using reaction matrix linked to the variable. The reaction matrix can be configured to detect any value <>'' as limit.
    Or you program the solution using some numerical variable and alarm texts in reaction matrix - depending on variable value.
  1. Zenon logic
    By sidramsatyal in forum straton / zenon Logic
    Last Post: 1st July 2014, 09:45
  2. IEC61850 Commands through Zenon Logic
    By knubla in forum Drivers
    Last Post: 16th May 2014, 12:12
  3. Zenon Logic Redundancy
    By davide.galigani in forum straton / zenon Logic
    Last Post: 24th April 2013, 07:22
  4. Runtime completely blocks right at the start
    Last Post: 30th April 2011, 15:21
