Thread: How can one reset a graphic on a button
    21.05.2014
    32
    Default How can one reset a graphic on a button
    It is really a beautiful option than, I can display a graphic when a button is pressed. But, I Couldn't figure out, How can I reset the button to normal (previous). Is there a way?
    Thanks!
    Jyo
    24.07.2008
    89
    Default AW: How can one reset a graphic on a button
    Hello Jyo,
    are you using the button as a switch with a linked variable?
    If yes then you would need to activate 'Momentary switch' and 'Momentary switch On', to get the desired behavior.
    Or are you using a function? Then the 'Graphics file for pressed' should only appear when the button is pressed.
    Konstantin
    21.05.2014
    32
    Default Re: AW: How can one reset a graphic on a button
    Hello Konstantin,
    I am using a button with function, Since I have to use a lot of buttons to display objects and respective functions. Now, I have set a graphic to display when a particular button is clicked, and it stays displaying the graphic also when the button is released (which is not a problem for me). But I am looking for some option to reset the graphic to normal button (without close the screen.) Is there an option to refresh the screen?
    Thanks!
    Jyo
    Quote Originally Posted by konstantinf View Post
    Hello Jyo,
    Konstantin
  1. Graphic Reports
    By mv-goncharov in forum zenon Energy Edition
    Last Post: 5th July 2013, 13:20
  2. WinCE graphic
    By tihomir in forum zenon Operator
    Last Post: 24th May 2013, 01:02
  3. Replies: 1
    Last Post: 13th September 2010, 23:27
