Thread: Button creation
    Default Button creation
    Hello
    I would like to create a switch button to change the value on bool tag. In function configuration the only parameter that can be used for this goal is "set the value" but during runtime operation when I press that button appears pop-up window. My question is, how to make the button set the value with out pop up window just by pressing it.
    When I use "Intern-Driver for internal variables" I can configure the button like a switch. But when I use any other driver ( Beckhoff for example ) button became unpressable and can not be pressed..
    With regards
    13.08.2013
    57
    Default Re: Button creation
    when you configure your SetValue Function, activate the Checkbox "Direct to Hardware", then the Value will be written without the PopupWindow
    Best regards
    Sigi
  1. Button
    By rookie in forum zenon Supervisor
    Last Post: 28th September 2010, 06:52
  2. Button
    Last Post: 24th September 2010, 12:20
  3. button ausgrauen
    Last Post: 5th May 2010, 12:49
  4. Import / Automatic creation of Variables in STRATON
    By prasadkh in forum straton / zenon Logic
    Last Post: 29th December 2009, 01:19
