Thread: Symbol editor base area moving from 0,0
    Default Symbol editor base area moving from 0,0
    Hello, support team.
    As it known, symbol elements are placed inside and outside of base symbol area, which is adjusted in single General properties group (bg color, width and height properties).
    When then symbol is placed on screen its coordinates counted from 0,0 of base area.
    This is good and understandable.
    Question is why, if it possible to give some symbol elements from symbol negative coordinates (which is pretty well working at all), we cannot see it in editor without select all symbol content, move it down and right, edit and then return all on base place carefully.
    In other words it will be very useful if you will add two properties into General group for setting DeltaX[pixels] and DeltaY[pixels], to have an ability to move symbol content with base area right and down, and see whole symbol without unneccesary steps (see attachement picture).
    Question is - Is there some hope that this usibility defect will be fixed in some next versions of zenon?
    Andrey
    24.07.2008
    88
    Default AW: Symbol editor base area moving from 0,0
    Hello Andrew,
    thank you for your input.
    I like this idea and will forward it to our product management.
    Konstantin
  1. symbol editor keyboard actions question
    Last Post: 11th June 2014, 07:25
  2. moving teh picture is not possible...
    Last Post: 26th June 2013, 12:17
  3. Alarm area inside another alarm area
    By davide.galigani in forum zenon Supervisor
    Last Post: 10th May 2012, 08:16
  4. Moving RT on Memry Stick
    By rob336ert in forum zenon Supervisor
    Last Post: 2nd April 2012, 00:17
  5. export SQL base
    By captain in forum zenon Supervisor
    Last Post: 24th August 2009, 14:13
