Thread: Access to internal variables not linked to a screen
    06.12.2012
    6
    Default Access to internal variables not linked to a screen
    I have created some internal variables which are not linked to any of the screens. However I would like to use their values in a VBA macro run either by a button or by a time function.
    If I try to get their values by method:
    thisProject.Variables.Item("intern1").value
    it looks as if they were not initialised unless they are linked to any of the objects in the active screen. Is it possible to initialize them during the application boot?
    All the Best,
    Piotr
    louis.paglaiccetti Gast
    Default Re: Access to internal variables not linked to a screen
    Is the variable you want to read "advised" (visible in a screen, in an online container, defined as an alarm, set to DDE active/Permanently Read Variable", ...)
    If not, you won't be able to read a value until the variable is advised.
    Have also look at:
    http://www.copadata.com/forums/showthread.php?t=1129
    http://www.copadata.com/forums/showthread.php?t=1074
    http://www.copadata.com/forums/showthread.php?t=1542
  1. Remanence of the internal variables
    By andrey_k in forum zenon Supervisor
    Last Post: 25th October 2013, 12:13
  2. How to access linked symbol sub elements
    By carlo.chiari in forum VBA
    Last Post: 1st October 2012, 14:03
  3. Search Variables & linked Objects
    By derda in forum zenon Supervisor
    Last Post: 3rd February 2011, 00:36
  4. Internal Variables
    By jamesleary in forum zenon Supervisor
    Last Post: 13th November 2008, 14:36
  5. PLC Variables and Internal Variables
    By madphilly in forum Drivers
    Last Post: 4th June 2008, 06:59
