Thread: Zenon server & Client Connection
    18.06.2013
    29
    Default Zenon server & Client Connection
    Hello Everybody
    Am facing one problem in Zenon Run time Server and Client connection establishment.
    I have installed Zenon run time & Web server in one machine and Client on another machine.
    I am getting screens from Zenon Run time to Zenon client machine but the problem is that am unable to get the values from Zenon run time machine to Client machine.
    Zenon client showing all values Zero.please refer the snap shots of Run time and Client machine screens.
    What could be the problem???
    Can you please help on this task how can we do this.
    Best Regards,
    Sidram
    Attached Thumbnails Attached Thumbnails Runtime Screen.jpg   Client Screen.jpg
    Default Re: Zenon server & Client Connection
    which driver is used for the variables?
    If it is the "Internal Driver", you have to switch the property Internal Variable -> Calculation at the variable to Network.
    Hi Sidram,
    Could it be that these variables are variables from the "Intern" driver?
    If that is the case, you can select the behavior of internal variables in the network, in the variable properties, for each variable. You can choose "local", which is the default, and "network", which makes these variables globally available in the network.
    18.06.2013
    29
    Thanks for the reply it's working fine.
    Thanks again for valuable reply.
    Regards
    Sidram Satyal
  1. WebServer - Client Connection
    By abcd1234 in forum Webserver/Webclient
    Last Post: 13th January 2014, 19:35
  2. zenon Web-Client 7 -> Web-Server 6.22 slow startup
  3. Server & Client monitor configuration
    By roberto1978 in forum zenon Network
    Last Post: 10th January 2011, 23:19
  4. zenon server acting as a client
    Last Post: 7th January 2010, 07:42
  5. connection failed between zenOn and STRATON
    By bernhards in forum straton / zenon Logic
    Last Post: 21st August 2007, 07:52
