Thread: VB .net program
    23.06.2014
    3
    Default VB .net program
    Hi
    I want a Vb . net console program with no interface to read a cmp file for a system and write out all records for a certain issue date month.Suppose we take a existing cmp file i need all records with issue dates as January in a new cmp file.we have to repeat for each month of the year and final output i need is 12 files with each months data.
    the format of a an existing cmpfile is as below
    01 2760M HAP 11001 19960117050SD38722 11MSA0000000198
    01 2760M HAP 11001 19960117050SD38722 7015081
    Yellow is the issue date in YYYYMMDD format
    Green is teh policy number
    please help me with this
    23.06.2014
    3
    Default Re: VB .net program
    Hi Can anyone help me with this ?????????????????
    23.06.2014
    3
    Hi
    01 2760M HAP 11001 19960117[COLOR="rgb(139, 0, 0)"]050SD38722[/COLOR] 7015081
    Red is teh policy number
    Hi twilight,
    I'm not sure if this forum is the best place for getting assistance with this specific request, as it is not necessarily zenon related.
    martins Gast
    hi,
    Something like this should do the trick:
    http://stackoverflow.com/questions/1...ntain-a-string
    best regards,
    Martin
  1. Converting Main Program to UDFB
    By sidramsatyal in forum straton / zenon Logic
    Last Post: 25th October 2013, 08:53
  2. Start Program Transfer Parameter
    Last Post: 4th May 2011, 01:45
  3. Start Program error with parameters
    By maurodx in forum zenon Supervisor
    Last Post: 16th November 2009, 06:51
  4. ext. program start in CE5.0 system
    By rgnos in forum zenon Operator
    Last Post: 2nd August 2009, 22:28
