Thread: Get data from aggregated archive
    08.12.2013
    27
    Default Get data from aggregated archive
    Hi support,
    Is that possible to get value from aggregated archive to internal variable?
    My application is I need to get aggregated archive value for mathematic calculation, my thought is get aggregated archive to store in internal variable and calculate in mathematic variable.
    Thanks!
    tobiassedlmeier Gast
    Default Re: Get data from aggregated archive
    Hello yitlilee,
    with the report generator you can write values from the archive to internal variables. There is also a zenon function where you can execute the report in the background.
    Tobias
    27.06.2011
    96
    Default AW: Get data from aggregated archive
    hello yitlilee,
    you can do this with the Report generator. Maybe it is not even necessary to store the Archive value into an internal variable. You could try and do the calculation directly in Report Generator.
    You will Need the Report functions =Archive() to read the Archive value and =variablerw() to write the value (or the result of the calulation) into a variable.
    Note that even though we´re talking about Report Generator, it is not necessary to actually Display the Report. You can just execute it so it will read and write the values.
    regards,
    Alex
  1. Archive filler value
    By jurijcadez in forum zenon Service Engine Supervisor
    Last Post: 30th January 2013, 11:49
  2. Zenon archive issue (archive inactive)
    By eugenius in forum zenon Service Engine Supervisor
    Last Post: 24th August 2012, 08:19
  3. Archive report
    Last Post: 10th August 2011, 02:34
  4. Archive refresh
    By bojan in forum zenon Service Engine Supervisor
    Last Post: 3rd April 2011, 23:15
  5. Archive vName
    By stimpfig in forum VBA
    Last Post: 10th May 2010, 15:14
