Thread: Change Numeric display color on inactive
    19.10.2010
    24
    Default Change Numeric display color on inactive
    Each numeric display has the ability to show a red box when variable is not communicating with the controller. Is it possible to change the text color when not communicating instead?
    I have been able to change the background using a combined element animating a rectangle symbol. I do not know how to tie a combined element to a numeric display if it is possible.
    Bill Sneddon PE
    Default AW: Change Numeric display color on inactive
    this can be done as following:
    Create a symbol displaying the variable in numerical value element
    - Set the textcolor to red (or whatever you like)
    - Disable "Show status of the variable"
    - Any other customization...
    Create another symbol displaying the variable in numerical value element
    - Set the textcolor to black
    In your screen create a combined element
    - Use symbol 2 for the Default status
    - Create one state only evaluating the Invalid bit (1) (other status are . ) -> Display the first symbol.
    Kind regards,
  1. Replies: 5
    Last Post: 18th July 2014, 13:06
  2. press button - change color
    By rgv0021 in forum VBA
    Last Post: 28th October 2013, 08:05
  3. Replies: 1
    Last Post: 7th June 2013, 16:14
  4. Replies: 3
    Last Post: 1st May 2013, 21:31
  5. how to change text and color of invisible button
    By tanveerali in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 14th February 2011, 00:09
