Showing results 1 to 1 of 1
Thread: Communication Between Zenon to RS Logix-5000
    30.05.2013
    119
    Default Communication Between Zenon to RS Logix-5000
    Dear Support Team,
    I am using Zenon 7.00
    I am trying to do the communication between Zenon to RS Logix-5000 with RSLinx Classic gateway using Emulator.
    Allen-Bradley ODVA driver:
    I did the configuration in SCADA as follows,
    1. Driver Configuration (Ref: ODVA Driver_config.jpg):
    I assigned the Net address is "1" and used this same in variable. Is this related with RSLogix-5000 or RS Linx...? If it is, where can I see in PLC side...?
    CPU slot number is "3". This is the slot number assigned in RSLogix-5000 and Emulator (RS-Logix 5000 Controller.jpg). Is this correct...?
    2. Variable Configuration (Ref: Var_Config.jpg):
    Net address is same which is assigned in driver configuration. I assumed the Bit number "0" is the first bit used in RSLogix-5000. Is it correct...?
    3. RSLinx in SCADA machine:
    Emulator (AB_VBP-1) and RSLogix machine (IP: 192.168.1.59) is running (Ref: RS linx sts.jpg).
    Please explain me If I need to do any further settings or correction in the existing configuration.
    Allen Bradley RS-Linx driver:
    Please explain the following things for the configuration of Allen Bradley RS-Linx driver,
    1. I selected the PLC type as a PLC2. Is this correct for RSLogix-5000 run by Emulator...?
    2. Please guide me where can I see the Net address, PLC2 data table address, File number and Element in the RSLogix-5000 or RSLinx (Ref: RS linx sts-Driver.jpg).
    Best Regards,
    A. Navaneet.
    Attached Thumbnails Attached Thumbnails Driver_config.jpg   RS linx sts.jpg   RS linx sts-Driver.jpg   RS-Logix 5000 Controller.jpg   Var_Config.jpg
  1. Communication Between Allen Bradley and Zenon
    By vivekgadre in forum Drivers
    Last Post: 4th June 2019, 14:06
  2. Ethernet IP Communication
    By amolck in forum straton / zenon Logic
    Last Post: 15th March 2010, 06:11
  3. communication Error again
    Last Post: 8th May 2009, 11:45
  4. Communication Error!!
    Last Post: 30th April 2009, 09:33
