Thread: WebClient install questions
    Default WebClient install questions
    Hello support team.
    We use 7.10 SP0 Build 10378
    1. During install of WebClient sometimes pending VSTA is asked even if Editor and Runtime are already installed.
    If we have Internet connection this VSTA package is downloaded and installed from copadata website automatically.
    But sometimes we have not Internet during install. Where can we download this package to install it manually before WebClient installation.
    2. In DVD\setup\wwwroot\controlversions\version710SP0 folder we found two webclient installation packages - webclient and webclient_small. From index.html start page we can only acces to 50Mb webclient_small package. What is the difference between packages?
    Andrey
    Default AW: WebClient install questions
    the difference between the two setups is that in the big setup the necessary prerequesites are included (like VSTA, VCRedist, etc.)
    So regarding your 1st question you could use the big setup when having no internet access.
    For making the big setup accessible via your index page you would need to manually alter the html page in the IIS folder of the Webserver (using a text editor for example):
    Installing the zenon web client
    Download the zenon web client control setup (7.10 SP0).
  1. Questions regarding functionality
    By mightor in forum zenon Supervisor
    Last Post: 16th March 2012, 16:00
  2. Many questions about IEC 60870-104
    By focus in forum zenon Energy Edition
    Last Post: 11th July 2011, 08:45
  3. WPF questions
    By zenmyway in forum VSTA
    Last Post: 28th November 2010, 23:57
  4. Questions about Archive and ArchiveED
    By nblanquart in forum VBA
    Last Post: 29th April 2010, 09:44
  5. Two questions about Message Control
    By lephis in forum zenon Network
    Last Post: 7th July 2009, 14:59
