Thread: Standard Recipe and string variables
    flajoso Gast
    Default Standard Recipe and string variables
    Hi all!
    i would like to use string variables within the Recipes (don't know if it is possible with Standard Recipe...), for example:
    Product code: XPTO (Recipe Name, ok)
    Product code_number: 123
    Product Description: bla bla bla (String Variable)
    Product Var: 456 (int)
    Product Var2: 789 (int)
    and so on.
    because i would like that the runtime user could change the product description. I was thinking that i could solve this with REMA (product code -> Text variable) or with a list/combo box... but the problem will be when creating new recipes during runtime...
    Any comments/suggestions?
    Thanks in advance.
    Default Re: Standard Recipe and string variables
    unfortunately string variables can only be used in recipes when using the recipe group manager module, not in the standard recipes.
    flajoso Gast
    Ok, thanks anyway!
    regards
  1. Accessing the rgm recipe name combobox
    By andreacold in forum VBA
    Last Post: 24th February 2014, 14:35
  2. Recipe Group Manager (RGM)
    By robertf in forum VBA
    Last Post: 2nd March 2010, 16:21
