Thread: Report Viewer. Custom Assemblies
    29.06.2010
    3
    Default Report Viewer. Custom Assemblies
    Can you help me with Report viewer?
    I tried to include library, for example, System.Data or custom lib and in RT I can't see my report.
    In Report Builder Assemblies is work(in Preview mode).
    Windows 7 x86, Sprecon-V460 v7.10 build 7770
    Viacheslav
    Attached Thumbnails Attached Thumbnails report_ref.png   code_dll.png   exp_txtbox.png   preview_work.png   zenon_rt.png
    Default Re: Report Viewer. Custom Assemblies
    Hi slaff,
    I don't have experience with this myself and am not sure if this actually works. Have you tried putting the compiled assembly in the same directory as the .rdl file for the runtime files?
    Are there any particular error messages logged to the diagnosis server when you open the report in the runtime?
    29.06.2010
    3
    Thanks for answer,
    Yes, I saw it in diagnostic viewer and the first problem is solved, I used NET framework 4.0 in my assembly, when it's need to be use 3.5. But now I have a new problem. When I use a reference to my assembly, in RT I see this message (pic1).
    Maybe there is some configuration file where I can change the settings for the display Report Viewer?
    Hi slaff,
    As said earlier, I haven't done this myself and am not sure if this is actually possible. But if you do manage to get it to work, it would be great if you could post an examle here in the forum
    Googling a bit for your error message, I found the following which could be helpful:
    http://blogs.msdn.com/b/mosharaf/arc...ustomcode.aspx
    http://stackoverflow.com/questions/2...al-rdlc-report
    http://social.msdn.microsoft.com/For...ted-assemblies
    http://jachman.wordpress.com/2007/12...-with-reports/
    tobiassedlmeier Gast
    I'm not sure if it will works to implement a dll in the Report Viewer. As I know the dll will be executed at the reporting Server. The Report Viewer is just a Client and the dll will not be executed. I tried the same thing. My DLL worked at the zenon Analyzer (here we have the reporting Server) at a Report. The same DLL didn't work at the Report Viewer.
    I'm not sure but I think this will not work with the Report Viewer. This is just a Client.
  1. Hide Report Viewer Toolbar
    By bosch_sigpack in forum zenon Service Engine Supervisor
    Last Post: 22nd April 2015, 08:42
  2. Filter option in Report viewer
    By jahidbagwan in forum zenon Service Engine Supervisor
    Last Post: 12th December 2013, 12:28
  3. Report Viewer
    By sidramsatyal in forum zenon Service Engine Supervisor
    Last Post: 5th September 2013, 06:13
  4. Trend with Report Viewer
    By eyup.agpinar in forum zenon Service Engine Supervisor
    Last Post: 20th August 2013, 00:32
  5. Report Viewer
    Last Post: 8th June 2013, 11:55
