Thread: Historian SQL Server
    18.09.2012
    13
    Default Historian SQL Server
    Hello all,
    I am currently exploring Historian SQL Server (Archive permanently on SQL database and not .arx)
    I found out that there is some predefined data structure (Timestamp, ms, Status, Value, ....)
    What I would like to achieve:
    Using an already existing table with a different datastructure and display it's data in ETM.
    Is it possible to modify the predefined database structure of zenon?
    Default Re: Historian SQL Server
    Hello Junior,
    Unfortunately not. The ETM relies on the historian to provide the data. The historian uses a predefined format to store the data in the database.
    When you have data from other sources that you would like to include in data analysis together with data from a zenon runtime, the zenon Analyzer may be interesting for you.
    18.09.2012
    13
    Default AW: Historian SQL Server
    Ok, I understand.
    Could you provide a download link for analyzer or set my user rights that I can download from website?
    I expect there is also a demo/evaluating period, same like editor?
    Hello Junior,
    It's probably best to contact your local sales reprasentative when you want to learn more about the options ofthe zenon Analyzer and what options are available to trial this product.
  1. Ideal Configuration for Evacuating to SQL Server
    By hoancai in forum zenon Supervisor
    Last Post: 8th August 2013, 08:06
  2. SQL error when I try the archive server function
    By lephis in forum zenon Supervisor
    Last Post: 23rd April 2009, 14:20
  3. SQL Server Logdatei
    By kwb in forum zenon Supervisor
    Last Post: 3rd March 2009, 12:00
  4. Timeseries data and SQL Server
    By nsko in forum Drivers
    Last Post: 28th May 2008, 08:20
  5. Version 6.21; SQL Server installation fails
    By stefan_m in forum Editor and Runtime Setup
    Last Post: 12th September 2007, 07:40
