Thread: Event in „Dachprojekt“ on alarm occurrence in an underlying project
    29.07.2007
    Germany
    192
    Default Event in „Dachprojekt“ on alarm occurrence in an underlying project
    Hello everybody!
    Is there a way to get a VBA event in the “Dachprojekt” in case of alarm occurrence in one of the projects under the “Dachprojekt”.
    Sample out of the help:
    Dim WithEvents zAlarm As Alarm
    'procedure is executed on startup of the zenOn runtime
    Private Sub Project_Active()
        'init the alarm object for events
        Set zAlarm = thisProject.Alarm
    'procedure is executed when an Alarm comes
    Private Sub zAlarm_AlarmComes(ByVal obItem As IAlarmItem)
        'print specific information to Debug window...
        Debug.Print obItem.Timecomes & " > " & obItem.Text
    'procedure is executed on terminating the zenOn Runtime
        'free the alarm object
        Set zAlarm = Nothing
    The sample is only working for alarms of variable located in the “Dachprojekt” no event is created for alarms in the projects under the “Dachprojekt”
    We need to know in the “Dachprojekt” information of the underlying projects:
    What alarms are active, are they acknowledged. Event based reacting on this information in VBA of the Dachprojekt is needed.
    The underlying projects can’t be changed since they are not in our hands we have to use them as they are.
    Thanks for any input!
    By the way "Dachprojekt" in english?
    H.-P.
    robertf Gast
    Default Re: Event in „Dachprojekt“ on alarm occurrence in an underlying project
    Hello hp!
    "Dachprojekt" means the project on the top of the project hierarchy. In English you may call it RoofProject...
    Here is a small Sample how to get the Alarm Events from SUB Projects:
    Dim WithEvents obALARM As Alarm
    Dim WithEvents obSubPrj As Project
    Private Sub obALARM_AlarmAcknowledged(ByVal obItem As IAlarmItem)
        Debug.Print "* " & obItem.Text & "  >> " & obItem.Projectname
    Private Sub obALARM_AlarmComes(ByVal obItem As IAlarmItem)
        Debug.Print "+ " & obItem.Text & "  >> " & obItem.Projectname
    Private Sub obALARM_AlarmGoes(ByVal obItem As IAlarmItem)
        Debug.Print "- " & obItem.Text & "  >> " & obItem.Projectname
    Private Sub obSubPrj_Inactive()
        Debug.Print "SUB Project is not longer available"
        'alarm events of this project are not fired until it is reinitialized
        Set obSubPrj = Application.Projects.Item("SUB1")
        If Not obSubPrj Is Nothing Then
            Set obALARM = obSubPrj.Alarm
        End If
        Set obALARM = Nothing
        Set obSubPrj = Nothing
    I hope it helps
  1. The event OnElementCreated is not executed
    By markclemens in forum VBA
    Last Post: 21st February 2008, 14:31
  2. Replies: 3
