Thread: Reaction Matrix
    25.03.2008
    14
    Default Reaction Matrix
    After I have created a Reaction Matrix, I'm able to select it on variable setting but I don't see it on the Reaction Matrix editor. It does the same for all other project in this computer but on my virtual computer, I can see all the reaction matrix that have been created. Do I need to re-install Zenon? What should I do?
    Default Re: Reaction Matrix
    which REMA Typ did you create?
    Where do you look at, when you assume the rema to appear?
    Which version of zenon do you currently use?
    Any screenshots will be appreciated.
    brandt Gast
    Is it possible that you have some filtering in your REMA dialog? If there is set a wrong filter, nothing will appear.
    25.03.2008
    14
    Right, a filter was there.
    Thanks!
