Thread: DNP3 comm with S7-1200 module CP 1243-1
    28.07.2010
    16
    Default DNP3 comm with S7-1200 module CP 1243-1
    hi support,
    I'm testing the above module to communicate with zenon 7. Unfortunately i cannot connect and receive the error as per attach ?
    Any idea why this error comes out ? We did the same way we had done with s7-1200 modbus tcp/ip. We created datablock and assign offset as requested.
    Default Re: DNP3 comm with S7-1200 module CP 1243-1
    Hi misbah,
    I'm not familiar with this module and the screenshot does not provide too much information. If possible, create a wireshark sniff and post it here.
    Generally, you would need to configure the DNP32 driver correctly.
    - set the DNP slave ID correctly in the driver
    - set the DNP master ID correctly in the driver
    - check that you use the correct net address at the variables that match the connection in the driver configuration.
    When you are using zenon version 7.10, I would recommend using the DNP3_NG driver instead.
  1. Driver for Siemens S7-1200
    By peterg in forum Drivers
    Last Post: 3rd May 2019, 17:24
  2. zenon unable to connect to S7-1200
    By misbah in forum Drivers
    Last Post: 17th June 2018, 13:54
  3. Comm.Failure and related animation
    Last Post: 9th October 2013, 04:01
  4. TCP/IP Comm problem
    By scotttee in forum Drivers
    Last Post: 6th October 2009, 13:16
  5. CE Device won't comm. with PLC
    Last Post: 9th March 2009, 14:13
