Thread: Web Client
    16.12.2010
    32
    Default Web Client
    Hi, All
    Regarding a Web Server,
    using a zenon 7.10 sp0 , web server standard.
    when web client is started on other site , it has a error. (static ip : 88.201.53.179)
    but, web client is work on web-server pc.
    so, i attached some pic about setting on web server , runtime server and firewall.
    plz tell me any info.
    i can not leave this site -.-
    * you can connect it with URL (88.201.53.179\zenon\index.htm)
    * diagnosis viewer :
    NetSrv WINSOCK ERROR--GetHostByName Failed Server:STP-OP1 Port:1102 GetHostByName error #11004
    attached file list
    1. configuration
    2. web-server PC gloval... , hosts etc
    3. Runtime server PC hosts
    4. Firewall set
    louis.paglaiccetti Gast
    Default Re: Web Client
    Hello gyu,
    Looking at your description and powerpoint, it appears as if your configuration on the zenon side is correct. Or at least, I do not see any obvious errors. This error message leads me to believe there is still a network related issue concerning name resolution.
    Perhaps as a test, you can verify that you can successfully ping in the following situations:
    - From the Web Client can you PING the Web Server via HOSTNAME?
    - From the Web Server, can you PING the runtime server via HOSTNAME?
    Can you successfully launch another web client from the INTERNAL network? If so, it may be worth investigating the Cisco firewall configuration. Additionally, if the web client successfully starts on web server machine, then I think that significantly narrows your problem down to network related issues (firewall, DNS, etc.).
    Here are some additional topics that may be worth checking:
    • Is the name resolution in the network working correctly?
    • From the remote web Client computer can you ping the Server by hostname?
    • From a remote web Client computer can you ping the Server by IP address?
    • (a ping by must always return the identical name (Case sensitive!) on all PCs, use the option ping -4 to force IPv4)
    • Try to delete the %TEMP% directory on the web Client computer.
    • Try to add the URL of the zenon web Server to the “Trusted Sites” of Internet Explorer.
    • In Internet Explorer 10, try to turn on “Compatibility Mode” in the Tools menu.
    • Disable/uncheck memory protection in the browser (Tools -> Internet Options -> Advanced -> Enable memory protection to help mitigate online attacks).
    If you still are unable to find the error, it would be highly suggested to contact your local Copa-Data support representative at that point.
    16.12.2010
    32
    Regarding a Enable DEP,
    Should i uncheck a Enable DEP on the web server PC ??
    879
    DEP needs to be deactivated on the PC where the WebClient is running when using the browser Internet Explorer (and only if VBA is used in the project)
    -> see http://www.copadata.com/forums/showthread.php?t=2327
    regards,
    herbert
  1. Web client. Using archive module
    By natali in forum Webserver/Webclient
    Last Post: 7th November 2013, 13:03
  2. zenon Web-Client 7 -> Web-Server 6.22 slow startup
  3. Web client subprojects error
    By jurijcadez in forum Webserver/Webclient
    Last Post: 17th May 2012, 23:34
  4. Web client VBA
    By jurijcadez in forum VBA
    Last Post: 15th May 2012, 14:43
  5. Internet Explorer 8.0 for Web-Client ?
    By lephis in forum Webserver/Webclient
    Last Post: 3rd June 2011, 06:34
