Thread: CEL cyclic export V7.10
    23.07.2013
    6
    Default CEL cyclic export V7.10
    I´d like to configure a cyclic export of the CEL into a .csv file.
    I trigger the CEL export function with a time control each 10 seconds for example, which
    works pretty fine.
    After the 2nd execution of the function (after 20seconds) there´s a pop up in the runtime telling that the file already exists. In this pop up I´m able to click No=attach or Yes=overwrite.
    Is there a possibility to avoid this pop up and set this function to "attach" permanently? Can this be done in the project.ini, and if, then how?
    Thanks for your help in advance.
    Regards topo
    23.07.2013
    6
    Default AW: CEL cyclic export V7.10
    The popup-window can be avoided by changing a setting in the project properties.
    Project properties > Runtime settings > Runtime messages for > Replace files (untick).
  1. Alarm XML Export
    By stimpfig in forum VBA
    Last Post: 16th July 2014, 15:53
  2. Auto export of CEL mix up events in export files...
    By ttj in forum zenon Supervisor
    Last Post: 10th September 2013, 07:34
  3. Export CEL to SQL
    By skywalker in forum zenon Supervisor
    Last Post: 14th September 2010, 12:24
  4. is there a way to change the export path in the RT(CEL
    Last Post: 10th December 2009, 19:20
  5. Datentyp export
    By lunzer in forum zenon Supervisor
    Last Post: 30th November 2009, 02:09
