Thread: Sending current values via e-mail
    09.04.2013
    57
    Default Sending current values via e-mail
    is it possible in Zenon ( and how to do it), to automate the following actions:
    -reading measurement variable every hour
    -sending variable value via e-mail every hour
    Thanks.
    Regards
    09.04.2013
    57
    Default Re: Sending current values via e-mail
    Anyone???
    880
    export the needed online variable values via function to i.e. *.txt file
    using "E-mail message via SMTP" and then attach the *.txt file to the message
    Manual -> Variables -> Functions for variables -> Export data
    Manual -> Message Control -> Configure Message Control -> General settings for sending -> E-mail message via SMTP
    Manual -> Message Control -> Configure Message Control -> Functions -> Send a Message -> Message -> E-mail message via SMTP
    regards,
    herbert
    09.04.2013
    57
    It works.
    Thanks.
    One more thing...I was not able to send an .TXT attachment with e-mail from Zenon, only the graphic file. Can it be done (send e-mail from Zenon with .TXT attachment)?
    Regards.
  2. Message sending via function
    Last Post: 17th September 2013, 14:09
  3. Current user in header section of the project
    Last Post: 31st July 2013, 10:02
  4. Sending command with IEC850 and communication error
    Last Post: 24th October 2012, 08:37
  5. E-Mail Versand Alternative zu Outlook
    By vogt in forum zenon Network
    Last Post: 10th May 2011, 10:31
