Thread: Unhandled exception
    29.12.2013
    Default Unhandled exception
    when the HMI- SCADA system run after completing windows boot up an error massagge come which shown as "AN unhandled exception has occoured , an error file has been written. Please restart Zenon and send the error file to COPA-DATA support "
    The error file name is
    c:\Program Files\zenOn550\Zenrt32.TXT
    ZenOn version 5.50 SP3 June 2002
    copyright COPA-DATA Gmbh
    Ser no. 1011805.13080.0.0
    At first we thought the program may be corrupted then we restore the system again from back up ISO file but same problem occure.
    I send you a attach file
    Please help us to find out the solution
    Thanks and Regards
    Thermax Group
    Bangladesh
    martins Gast
    Default Re: Unhandled exception
    hi,
    I guess the best solution for your problem here is to get in contact with your distributor where you purchased your zenon License as they can supply you with a build setup which may fixes your problem.
    best regards,
    Martin
  1. Replies: 3
    Last Post: 21st February 2013, 23:30
  2. Replies: 1
    Last Post: 28th April 2011, 23:37
  3. Unhandled Exception STACK_OVERFLOW
    By ptkdennis in forum zenon Operator
    Last Post: 16th February 2011, 14:36
  4. Seltsame Unhandled Exceptions
    By matthias.zoellner in forum VBA
    Last Post: 3rd April 2009, 13:23
