Thread: Message control
    23.09.2013
    10
    Default Message control
    when i am attepent to send message useing zenon (mesage control) on CEL appear to me target user 0 missing, please can you help me and tell me what is the problem
    Note : i am using GDW-11 modem from westermo company and all thing it is ok, i can send message from modem tools, and zenon see the modem .
    09.06.2014
    9
    Default Re: Message control
    Quote Originally Posted by ziadnajjar View Post
    I Have the same problem!
    24.07.2008
    88
    Default AW: Message control
    Hey Jessica,
    this thread is like 7 months old, so I assume the problem from ziadnajjar might be solved already.
    Basically the error message indicates that the user (static or dynamic from a string variable) could not be found.
    I would advise you, to use the zenon diagviewer and check the log messages.
    Which zenon version are you using?
    Konstantin
    09.06.2014
    9
    Default Re: AW: Message control
    Hey konstantinf,
    Thanks for response.
    I had this problem with zenon 6.5
    I deleted all runtime files and rebuilt them, then my problem solved
    Jessica
  1. Message control menu
    Last Post: 2nd June 2010, 03:42
  2. Two questions about Message Control
    By lephis in forum zenon Network
    Last Post: 7th July 2009, 14:59
  4. Replies: 0
  5. Replies: 0
