Thread: Covert Hex to Bin
    23.09.2013
    10
    Default Covert Hex to Bin
    hi
    Please support me how i can convert one value from Hex to Bin format , this hex value coming from PLC over Modbus Protocol,,,
    another thing how i can using each binary bits individals beacuse each binary bit represents breaker status
    thanks for your quick responce for my issue
    regards
    20.07.2012
    6
    Default Re: Covert Hex to Bin
    Hi ziadnajjar,
    Regarding your second question:
    In order to have an access to the bit of variable in zenon Logic, you just have to put a dot "." at the end of variable name and then put the number of bit, which you would like to use/check/read.
    variableName.bitNo
    You can find detailed information in following zenon Logic help chapter:
    Programming languages - Reference guide -> Basic Operations -> Access to bits of an integer
    Regards
    Piotr
    23.09.2013
    10
    thanks
    15.12.2017
    How about the first question? Is there any way to convert a hex or integer value to a binary value using STRATON 9.1?
    Felix
    1,059
    Piotr has already answered exactly this question.
    In an integer variable you can access the whole value (then decimal or hexadecimal), or bit-by-bit. For example: if an UINT (so numeric 16-bits value) variable name is Dummy, then in ST-language you can access the lowest bit of this variable using syntax Dummy.0, the next bit: Dummy.1, the highest bit: Dummy.15
    06.01.2016
    2
    Quote Originally Posted by Felix View Post
    Felix
    Hi Felix,
    There is another solution, it is using the function block unpack8 to convert a byte to a set of 8 bits.
    It can be used in combination with HIBYTE, LOBYTE that converts words to byte, and HIWORD, LOWORD, that converts dwords to words.
  1. Replies: 1
    Last Post: 24th November 2010, 14:03
  2. Problem with Alarm.bin
    By cyrilfeasy in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 2nd December 2009, 23:02
  3. Dynamic limittext as Hex
    By kicker in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 14th August 2009, 12:20
