Thread: react on value change
    22.10.2013
    14
    Default react on value change
    Hello again,
    I have new question. Maybe I had to create new thread but I do not want the people are tired from me :-)
    I have 2 internal variables: var1 and var2 that they make some things in small vba program when they change their value.
    To change their value I have created 2 numerical values squares ok.
    The problem that I find is that when I make the changes in the numerical values, the vba program does not react until I link this program to one button and one event (for example...leftclickup).
    What i want is: WHEN I CHANGE THE VALUE IN THE NUMERICAL VALUE SQUARE, automatically the program in vba reacts and it is not necessary to press any button.
    30.05.2007
    Salzburg
    881
    Default Re: Drive, Dir and File List Box
    if you want to react on value changes then use the Online Container ChangeEvent()
    http://www.copadata.com/forums/showthread.php?t=41
    or also in the help documentation at
    Manual -> Programming interfaces -> Object model -> OnlineVariables
    regards,
    herbert
    Default Re: react on value change
    Hi rgv0021,
    Another alternative to using an online container is to use a numeric reaction matrix, create a status and set the value to "any", and activate the checkbox "treat each change of value as a new limit violation".
    At this status, link the "execute vba macro" function, and link the reaction matrix to the variables that are changed.
  1. Ip-Change(S7TCP32) with VSTA
    By s.jonigk in forum VSTA
    Last Post: 7th February 2017, 15:08
  2. Detect Language Change
    By yavaskoray in forum VSTA
    Last Post: 6th August 2013, 13:02
  3. flashing when value change
    By focus in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 23rd January 2012, 00:11
  4. how to change driver in runtime
    By victoria in forum VBA
    Last Post: 11th October 2011, 23:32
  5. Value changes are protocolled in CEL, although there is no change
    By markusw in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 21st August 2007, 08:15
