Thread: Reading 64-bit registers via Modbus
    04.09.2009
    84
    Default Reading 64-bit registers via Modbus
    Hi Support,
    We are using Zenon 6.51 SP0 on Windows Server 2008 R2
    There is a need to read a 64-bit double precision float value distributed in 4 consecutive modbus registers.
    The data type for modbus variable REAL is supporting only 32 bit range.
    Kindly assist how to acquire this value in zenon runtime.
    Default Re: Reading 64-bit registers via Modbus
    Hi Shikra,
    The easiest way is probably to update to the latest zenon version.
    04.09.2009
    84
    Hi Shikra,
    Any other alternative?
    955
    you can also read Modbus registers into 4 UINT variables configured as 'external visible'. Then in Logic you can - using functions SerializeIn/Out - copy them info single LREAL variable of stratonNG driver.
    (* declare:
    BUFFER : array of 8 USINT
    LRVALUE : LREAL value
    assuming UINT1 .. UINT4 are your 4 consecutive MODBUS words
    ... and that everything is big endian
    SerializeOut (BUFFER, UINT1, 0, TRUE);
    SerializeOut (BUFFER, UINT2, 2, TRUE);
    SerializeOut (BUFFER, UINT3, 4, TRUE);
    SerializeOut (BUFFER, UINT4, 6, TRUE);
    SerializeIn (BUFFER, LRVALUE, 0, TRUE);
    880
    as this inquiry from Shikra was also treaded via a ticket:
    -> solution to this was updating to the latest BuildVersion of zenon 6.51 SP0 (Build23) where the datatype LREAL for analog input (resp. holding register) is available
  1. Report Generator, Reading of Parameters from Cells for SQL-Query
    By luc in forum zenon Service Engine Supervisor
    Last Post: 9th December 2013, 09:23
  2. Reading Excel
    Last Post: 27th September 2013, 17:09
  3. Decoding the INT tag bit By Bit
    Last Post: 29th August 2012, 01:29
  4. Replies: 2
    Last Post: 29th March 2011, 10:46
  5. Replies: 1
