Thread: Change the text on a button in the runtime
    06.02.2013
    14
    Default Change the text on a button in the runtime
    Hi everybody,
    ís there no way to change the "Text1" from a button? (during the runtime runs)
    I have a button which triggers a macro. when i press the button the first time,
    i want to edit the Text1
    (start Event -> stop Event)
    when i press the button the second time
    (stop Event -> start Event)
    Other Options:
    create 2 Buttons at the same Location
    create 1 bool Variable named Eventstarted
    Button1.Text1 = stop Event
    visible from 1-1 (depends on the Variable Eventstarted)
    Button2.Text1 = startEvent
    visible from 0-0 (depends on the Variable Eventstarted)
    is there a better/easier way to manage the problem?
    Sven
    880
    Default Re: Problems with set_DynProperties
    no coding required for this:
    - take a button
    - link a bool-variable to it
    - configure the button as switch
    - at the button properties at "Representation" -> "Text line 1" you write "Start"
    - at the button properties at "Representation" -> "Text when pressed" you write "Stop"
    regards,
    herbert
    06.02.2013
    14
    Hi herbert,
    i tried it, but the button will only show "Stop", when the mousebutton is pressed. when i take my "finger away" from the mousebutton the button shows start, but that´s not what i want to have
    the button should show "start" until i press it.
    when i pressed it, the text should change to "stop", till i pressed it again
    (than it should show "start")
    regards,
    Sven
    880
    check out the properties of the button
    -> from your description probably the checkbox "Momentary switch" is enabled
    -> if so, please deactivate
    regards,
    herbert
  1. Replies: 5
    Last Post: 18th July 2014, 13:06
  2. press button - change color
    By rgv0021 in forum VBA
    Last Post: 28th October 2013, 08:05
  3. Replies: 1
    Last Post: 7th June 2013, 16:14
  4. how to change text and color of invisible button
    Last Post: 14th February 2011, 00:09
  5. Change Text Button with DynProperties
    By acko01 in forum VBA
    Last Post: 16th October 2009, 10:29
