Showing results 1 to 8 of 8
Thread: Different Eventhandlers for 1 OnlineContainer
    06.02.2013
    14
    Default Different Eventhandlers for 1 OnlineContainer
    Hi everyone,
    i have started handling with OnlineContainers and the eventhandler.
    i want to observe 20 variables..
    i just see 2 options to observe / manage the events:
    1. Create an OnlineContainer for every Variable to have an own Eventhandler
    (OnlineVariable_Var1.VariableChange +=
    new zenOn.VariableChangeEventHandler(OnlineVariableVar_1_VariableChange);
    (OnlineVariable_Var2.VariableChange +=
    new zenOn.VariableChangeEventHandler(OnlineVariableVar_2_VariableChange);
    2. Mange the different Events with a switch - Case request
    (OnlineVariables.VariableChange +=
    new zenOn.VariableChangeEventHandler(OnlineVariables_VariableChange);
    public void OnlineVariables_VariableChange(zenOn.IVariable obVar)
       string VarName = obVar.Name
       switch(VarName)
       case "Var1":
          do something
       case "Var2":
          do something
    Isnīt there a compromise, like one OnlineContainer but have "many" Eventhandler-mothods?
    Sven
    Default AW: Different Eventhandlers for 1 OnlineContainer
    why would you like to do this?
    If you are afraid of performance issues, with 20 variables there should be no issue at all.
    I would suggest solution 2. as it would be easier to manage (otherwise you would need to maintain 20 Onlinecontainers with its eventhandlers)
    06.02.2013
    14
    Default Re: Different Eventhandlers for 1 OnlineContainer
    HI bernhardf,
    first, thanks for your reply.
    I also suggest the second version...when there is no solution for my question.
    i would like to have more eventhandler for one Onlinecontainer, because with my second version, iīll get a method with 300 lines of code, or even more...
    iīll guess iīll go for something like that:
       switch(VarName)
       case "Var1":
          EventhandlerVar1_Changed();
       case "Var2":
          EventhandlerVar2_Changed();
    public void EventhandlerVar1_Changed()
       do something
    public void EventhandlerVar2_Changed()
       do something
    i just hate methoths which seems to never end... =)
    Sven
    yes, I would do it also like that.
    880
    just a quick question:
    - what exactly do you want to do (execute) in the ChangeEvent()?
    - what should happen if a value of a variable changes?
    regards,
    herbert
    06.02.2013
    14
    Hi herbert,
    itīs quite easy...
    i want to change a value of 1-4 other variables (depending on the Variable which has changing itīs value)
    first i have to know, which variable changes itīs value, than i have to check the dependency on other variables. if there is any dependency, i have to change the value of the other variables.
    at the moment i handle the Changeevents like this:
    (works finde for me)
       switch(VarName)
       case "Var1":
       case "Var2":
       do something
       do something
    Sven
    880
    you can evaluate values from different variables also via the mathematic driver. the mathematic variable (in which you link the input variables) is then the output of the calculation. at this mathematic variable you then can configure limits or also using a rema (reaction matrix) which executes some functions.
    Please have a look in the help documentation at
    Drivers -> MATHDR32
    Drivers -> MATHDR32 -> Driver-specific functions -> Formulas
    The help documentation can be opened i.e. via the zenon Editor on pressing "F1"
    regards,
    herbert
    06.02.2013
    14
    Hi herbert,
    all my variables i intereact with, have the S7TCPIP driver. i am fine with the solution i wrote in my last post. thanks =)
    Sven
  1. Replies: 17
    Last Post: 11th July 2013, 13:08
  2. Replies: 5
    Last Post: 12th January 2011, 11:06
  3. Replies: 5
    Last Post: 16th July 2009, 14:39
