Thread: press button - change color
    22.10.2013
    14
    Default press button - change color
    Hello all,
    PLEASE, SOMEONE CAN TELL ME WHAT IS BAD. I want to change the color of the button when I press this button. The steps that I followed are the nexts:
    1- I have created one screen called: Main_screen
    2- In this screen I have created a button: Button1.
    3- In Button1, I go to properties, VBA Macros I open the LeftClickUp and I select the proper Macro.
    4- I created the macro in the MacroList. The macro is called: LeftClickUp_Button1
    5- The text of the program in VBA is:
    Sub change_color()
    Dim myElem As Element
    Dim myScrn As DynPicture
    Set myScrn = thisProject.DynPictures.Item("Main_screen")
    If Not myScrn Is Nothing Then
    Set myElem = myScrn.Elements.Item("Button1")
    If Not myElem Is Nothing Then
    myElem.BackColor = RGB(89, 58, 12)
    End If
    myScrn.UpdateAll
    End If
    Public Sub LeftClickUp_Button1(obElem As Element)
    ´Call subroutine
    change_color
    WHAT IS BAD? I can not achieve anything.
    Thanks a lot.
    Roberto
    Default Re: press button - change color
    Hi Roberto,
    Thanks for your post, and welcome to the forum!
    You can easily change the color of a button without writing a single line of code.
    Check out the property "dynamic color". You can link a variable here. The limit colors of that variable can be used for e.g. the background color.
    This can be a variable of the internal driver.
    When this is a boolean variable, you can link the variable at the button (as a press button or switch) and if needed, execute a function through the limit of the variable.
    22.10.2013
    14
    OK.GOOD!
    Did it.
    Thanks.
  1. Replies: 5
    Last Post: 18th July 2014, 13:06
  2. Replies: 1
    Last Post: 7th June 2013, 16:14
  3. Button Press On Different Monitors
    By allmendinger in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 25th October 2011, 05:46
  4. how to change text and color of invisible button
    By tanveerali in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 14th February 2011, 00:09
  5. How to increment a variable on button press
    By matholton in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 24th September 2008, 12:51
