Thread: Change a variable at the function in the editor
    06.02.2013
    14
    Default Change a variable at the function in the editor
    i guess i have almost the same question, therefore i wrote into this thread.
    i want to change the linked variable of a function (value change function) with VSTA. i export the xml code to get the correct property name. (bold marked)
    Code:
      setInitValues
      TRUE
      FALSE
      FALSE
      FALSE
          1.000000
            0.000000
            1.000000
            TRUE
            FALSE
            FALSE
            VarName
            FALSE
    Isnīt it possible to change "just" the Variable?
    I tried something like
    "myZenWork.ActiveDocument.RtFunctions().Item("setInitValues").set_DynProperties("Variable", "otherVariableName");
    Sven
    06.02.2013
    14
    Default Re: change linked variable of an element during runtime
    Perhaps there is a way to edit or create a new Subitem (SetValue).
    I attached a picture with all the properties, but i donīt know, how do edit them in VSTA
    ProbsMain = get_PropertiesEnum("") of the Function
    probs = get_PropertiesEnum("SetValue") of the Function
    i hope someone got an idea to change the variable of the function...
    Sven
    Default Re: Change a variable at the function in the editor
    Hi Sven,
    I created a new thread for your posts, as this actually is quite a different topic
    See the example below:
            public void MacroConfigFunction()
                zenOn.IRtFunction svFunction;
                zenOn.IVariable vVariable;
                svFunction = this.ActiveDocument.RtFunctions().Item("trip");
                vVariable = (zenOn.IVariable)svFunction.get_DynProperties("SetValue.Variable");
                this.Application.DebugPrint(vVariable.Name, zenOn.tpDebugPrintStyle.tpMsg);
                vVariable = this.ActiveDocument.Variables().Item("S21_Outstation21_G10_1_usint");
                svFunction.set_DynProperties("SetValue.Variable", vVariable);
    06.02.2013
    14
    Hi markclemens,
    thank you for your advise. I tried it, and it works fine (even in Runtime with ProjectAddin)!!
    Sven
  1. Replies: 3
    Last Post: 23rd October 2013, 17:10
  2. Minimal external variable change interval to be hooked in zenOn
    Last Post: 24th September 2013, 18:38
  3. How to trigger a function when a variable changed?
    By denver in forum zenon Supervisor
    Last Post: 16th May 2012, 10:12
  4. Store variable data to file on change event
    By matholton in forum Drivers
    Last Post: 1st December 2008, 10:40
  5. Change variable status
    By brada in forum VBA
