Thread: Zenon 7.00 SP0 build4
    20.03.2013
    25
    Ausrufezeichen Zenon 7.00 SP0 build4
    Can we use Zenon 7.00 SP0 build4 with windows XP 2Go RAM?
    Default Re: Zenon 7.00 SP0 build4
    Hi Xeren,
    zenon 7.0 is still capable of running on Windows XP. In fact it is the last version of zenon that supports Windows XP. zenon 7.10 no longer supports Windows XP.
    You can find more information on the system requirements in the online help.
    Windows XP will reach end of life in April 2014 and therefore you may want to consider upgrading the operating system to e.g. Windows 7, or Windows 8 with zenon 7.10, for new installations.
    20.03.2013
    25
    Default Zenon7 & Windows XP
    Hi
    We have zenon 7.00 SP0 build4.
    Can we run the demo application on XP with 2GB RAM?
    Thank you
    Hi Xeren,
    Please keep track of your posts and try to avoid double posting
    In the User control panel, you can set an option to get notified by e-mail when someone replies to your threads. This may also help.
    Thanks,
    03.06.2017
    Default Re: Zenon7 & Windows XP
    Can anyone share Zenon V7.2 Scada Software Setup link.please help me it is very important.I want download link .
    18.02.2014
    22
    you can download Version 7.20 Setup from the COPA-DATA Homepage in the Download Area. Login with user is necessary.
  1. Problem mit den Farbpaletten unter Zenon 7.0 SP0
    Last Post: 13th July 2012, 15:26
  2. zenon 6.5 sp0 for windows 7 professional 64bit
    Last Post: 1st November 2011, 23:07
  3. Zenon 6.50 SP0 | Bitmap button
    Last Post: 21st December 2010, 13:33
  4. Zenon 6.50 Sp0 build 1 warning
    Last Post: 11th August 2010, 08:19
  5. zenOn-Editor 6.22 SP0 Build 3 beendet sich sofort nach dem Starten
    By maerz@staudinger-est.de in forum zenon Supervisor
    Last Post: 19th September 2008, 21:17
