Thread: Converting Main Program to UDFB
    18.06.2013
    29
    Default Converting Main Program to UDFB
    Hello Everybody,
    I have created zenon logic in main program(FBD). But i would like to use this program multiple times so i am thinking to convert this main project to UDFB. is it possible?
    josefm Gast
    Default Re: Converting Main Program to UDFB
    I think a converstion from FDB to UDFB is not possible easily.
    As far as I can remember I used copy and paste then, but mine was written in ST so it was kind easy.
    Maybe someone else has a better solution.
    05.09.2007
    8
    Select the part of your FBD then right click on it. Choose "Create UDFB with code..." in the contextual menu. This creates automatically an UDFB. All input- and output-lines will be turned into IN- and OUT Variables.
    Hope this helps.
  1. Main menu
    By ansab.tp in forum zenon Supervisor
    Last Post: 30th August 2012, 09:40
  2. Start Program Transfer Parameter
    By whitetaru in forum zenon Supervisor
    Last Post: 4th May 2011, 01:45
  3. Replies: 1
    Last Post: 24th November 2010, 14:03
  4. alarm status line & Main menu
    By roberto1978 in forum zenon Supervisor
    Last Post: 23rd November 2010, 07:10
