Thread: How can i duplicate VSTA ProjectAddin
    25.02.2013
    8
    Default How can i duplicate VSTA ProjectAddin
    i've 25 ZenOn projects in the editor.
    i've a VSTA ProjectAddin in one of this project with many .cs files.
    i want to duplicate the VSTA in all the projects.
    is it possible to duplicate quickly the VSTA project? (by copying files? import/export? other?)
    OR
    do I have to go into each project and manually create all cs files in the editor VSTA project?
    thx for ur help.
    martins Gast
    Default AW: How can i duplicate VSTA ProjectAddin
    hi,
    probably the nicest way to do this is by modifying the project addin template. You can find them in %cd_system%\VSTATemplates\
    The code when creating the ProjectAddin is stored in the Project TemplateXXXX.zip file (regarding the version number). You probably noticed that everytime you create a new project, there is already some code in it - this code is defined in the template which is shipped by the development - but as they are basically just zipped, you are able to modify the templates.
    You can open the zip and modify the code. Then, everytime when you create a new VSTA project (first time you try to open the ProjectAddin in a zenon project), the template is copied into your project folder.
    best regards,
    Martin
    25.02.2013
    8
    Default Re: How can i duplicate VSTA ProjectAddin
    OK ! thx
  1. Einstieg in VSTA C#
    By manfred_fh in forum VSTA
    Last Post: 8th November 2010, 20:24
  2. Replies: 1
    Last Post: 3rd August 2010, 10:02
  3. VSTA Startproblem
    By stimpfig in forum VSTA
    Last Post: 23rd February 2010, 15:47
