Showing results 1 to 7 of 7
Thread: Alarm Timestamp
    15.04.2013
    7
    Default Alarm Timestamp
    I want to know what is the source for the time stamp is displayed in the alarm message list for the "time received" column. Is it the system time?
    TIA
    Default Re: Alarm Timestamp
    Hi Kavya,
    That depends. For drivers that do not support external timestamping from the device or PLC, it is the system time when the alarm was created.
    For drivers that do support external timestamping, it can be the system time, but it can also be the external time that was included with the value from the device or PLC.
    You can add the column "variable status" in the alarm list to see if the alarm uses an external timestamp.
    In some cases even when a timestamp was included, it can still be the system time. E.g. for the DNP3_NG driver when the received time is 0 (01.01.1970) or for the IEC850 driver when the time quality indicates that the device time is not valid.
    Sorry, for the long answer, there is just not a simple "yes" or "no"
    880
    Default AW: Alarm Timestamp
    Please check out following chapter in the manual:
    Manual -> Runtime -> Handling of date and time
    If you have variables basing on a real-time capable driver (i.e. IEC870) then the timestamp is taken from the PLC (PLC sends value + timestamp) - external time stamping.
    regards,
    herbert
    880
    .... that was more or less synchronous double posting
    now let's hope that this answers the question
    15.04.2013
    7
    Hi mark,
    I am using DNP3 driver.I added variable status to the AML. The status is "SPONT-T_INTERN-T_STD". I am still unable to find out whether time stamp is external or PC time.
    880
    well ... you have your answer with the status "SPONT-T_INTERN-T_STD
    Manual -> Status processing -> Status bits
    Bit number: 22
    Short term: T_INTERN
    Long name: Real time internal
  1. IEC 60870 timestamp in zenon
    By abstinent in forum Drivers
    Last Post: 17th February 2013, 08:51
  2. Problems with alarm list and alarm time
  3. Alarm Status Line and Alarm List
