Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 11
Thread: Max.Storage time of Alarm Message list & Chronologic event list
    30.05.2013
    119
    Default Max.Storage time of Alarm Message list & Chronologic event list
    Dear All,
    What is the maximum storage time of the Alarm Message list & Chronologic event list...?
    Because I removed the Delete button in the Alarm message list and Chronologic event list screen for customer wish. Customer would like to know maximum storage time of these both.
    Best Regards,
    A.Navaneet.
    Default Re: Max.Storage time of Alarm Message list & Chronologic event list
    Dear A.Navaneet,
    Basically as long as there is free disk space on the volume where the runtime files are stored
    You can use system driver variables to monitor the free disk space.
    Usually there are some requirements from the customer like "keep records for x months", or "keep for x years".
    You can use the "file operation" function in the zenon runtime to periodically (e.g. every month) delete *.aml and *.cel files, that are older than 36 months. (you could also move the files to a different drive or network storage)
    30.05.2013
    119
    Dear Mark,
    Customer told me to store the event and alarm as long as possible.
    Is the zenon runtime delete the stored files automatically if there is no free disk space...?
    If it is not possible automatic delete then I try to use the "file operation" function in the zenon runtime to periodically delete *.aml and *.cel files, that are older than 36 months.
    Otherwise, if customer provide extra drive i try to move this file.
    I write my query on this same post if I have further doubt after trying once...!!!
    Best Regards,
    A.Navaneet.
    Hi A.Navaneet,
    No, the zenon runtime will not automatically delete any files.
    However if you have a look at an existing runtime, you will find that in general the historical alarms and events are actually quite small.
    On a regular industrial PC with a standard size harddrive, you would not likely fill up the free disk space during the lifetime of the industrial PC itself.
    You could trigger the move or delete function as a reaction to the limit of the system driver variable that monitors the free disk space. You can define your own time settings for moving or deleting files, it does not have to be 36 months, this was just an example
    30.05.2013
    119
    Thank you Mark.
    I try that delete function. If I have further doubt in this I post my query on this same.
    Best Regards,
    A.Navaneet.
    30.05.2013
    119
    Dear Mark,
    I am using zenon 7.00.
    I searched the function for deleting *.aml and *.cel files. There are some functions available like "delete alarm", "export aml", "export cel" etc. But I couldn't find any function like file operation. Can you please explain, where do I want look at for this?
    Best Regards,
    A.Navaneet.
    Dear A.Navaneet,
    Please check the category "Windows" in the dialog when you create a new function.
    Also, it may be worth checking the online help as well
    30.05.2013
    119
    Dear Mark,
    I searched the function, but I couldn't find. Please refer the Func.jpg snap, there is a expanded view of AML and CEL and Application functions. I searched other functions also. There is no function found related to delete .aml and .cel files. Now please explain which function can I use...?
    Best Regards,
    A.Navaneet.
    14.07.2010
    46
    Hello Navaneet,
    I think Mark means the function that can be found under the category Windows.
    It is the last entry of your screenshot. Take a look there.
    Daniela.
    30.05.2013
    119
    Dear Daniela,
    Please refer the following post which I got from Mark.
    "You can use the "file operation" function in the zenon runtime to periodically (e.g. every month) delete *.aml and *.cel files, that are older than 36 months".
    But there is no function found in the window which I have attached already for "file operation" or delete *.aml and *.cel. Please explain which function can I use for this...?
    If you see the snap there is function available like "Alarmelete" but this is for deleting individual alarm.
    Best Regards,
    A.Navaneet.
  1. Deleting Chronologic Event List
    Last Post: 7th October 2013, 22:54
  2. Problems with alarm list and alarm time
    By dario in forum zenon Service Engine Supervisor
  3. Remove scrollbars from Alarm Message List
    By davide.galigani in forum zenon Service Engine Supervisor
    Last Post: 29th March 2012, 00:53
  4. Time synchronization have problem in the alarm list
    By shahramkh59 in forum Drivers
    Last Post: 10th April 2011, 19:19
  5. Alarm message list entries
    By douglasm in forum zenon Service Engine Operator
    Last Post: 9th November 2009, 11:50
