Thread: Re: AW: Using Straton with Zenon
    yara Gast
    Default Re: AW: Using Straton with Zenon
    one more question please, i want to create 1500 variables in straton as o out put for zenon, and read around 1500 variables from zenon to straton to do the calculation. its ok with this number of variables or there are a limitation of number?
    Thanks in advance
    879
    Default AW: Re: AW: Using Straton with Zenon
    as mentioned it http://www.copadata.com/forums/showthread.php?t=2518
    create those 1500 variables (where you write the output of your straton calculation) in zenon (use i.e. internal variables) and share those variables to straton (extern visible)
    and about the number of variables:
    -> you may then have to adjust the "Max. Puffer" setting in zenon Logic (per default 1024 variables)
    -> see Manual -> zenon Logic -> zenon Logic Runtime (Soft PLC) -> User interface -> Settings -> Enhanced settings
    regards,
    herbert
  1. Using Straton with Zenon
    By yara in forum straton / zenon Logic
    Last Post: 3rd October 2013, 09:42
  2. straton-zenon shared variable
    By batabaha in forum straton / zenon Logic
    Last Post: 13th April 2012, 00:14
  3. How to link zenOn and straton in zenon6.22?
    Last Post: 29th March 2009, 11:37
  4. Straton on RTU32 and Zenon
    By bjoerndavid in forum zenon Network
    Last Post: 3rd January 2008, 09:03
  5. connection failed between zenOn and STRATON
    By bernhards in forum straton / zenon Logic
    Last Post: 21st August 2007, 07:52
