Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 14
Thread: How to create Function with linking rule with vba
    10.08.2012
    17
    Default How to create Function with linking rule with vba
    Hi all,
    I created function with code below, now I need to do linking rule for all variables in the picture "TestPicture". Is it possible with vba ?
    Br.
    Lukasz
    Dim zFCT As RtFunction
    Set zFCT = MyWorkspace.ActiveDocument.RtFunctions.Create("TestFunction", tpPicture)
    With zFCT
            .DynProperties("Picture") = "TestPicture"
    End With
    Default AW: How to create Function with linking rule with vba
    this should work:
    With zFCT
            .DynProperties("PictSwitch[0].Picture") = "TestPicture"
    End With
    Have a look at the attached screen and check the XML Export of your function for details.
    PictSwitch_0 in the XML has to be PictSwitch[0] in the code.
    Note that the PictFilter_0 settings are screen type specific, so it can be dangerous exchanging the screen afterwards.
    (As filters are screen type specific and might not fit after exchanging the screen/screen type, which is prohibited in the Editor anyway).
    10.08.2012
    17
    Default Re: How to create Function with linking rule with vba
    Maybe I didn't explain what exactly do I need to do in VBA.
    What I'm trying to achieve is:
    1. Create a function screen switch with VBA
    2. Chose a picture to open
    3. Find out what variable are on the picture
    4. Make a linking rule for all variables in the picture
    5. replacement for example: to .
    I'm expecting to create function like in the attachment.
    Br.
    Lukasz
    10.12.2007
    260
    Blinzeln AW: How to create Function with linking rule with vba
    Maybe this helps:
    Set zFct = thisProject.RtFunctions.Item("TestFunction")
    If Not zFct Is Nothing Then
        For i = 0 To CLng(zFct.DynProperties("PictSwitch.SubstiVar[-1]")) - 1
            zFct.DynProperties("PictSwitch.SubstiVar[" & i & "].Destination") = vba.Replace(zFct.DynProperties("PictSwitch.SubstiVar[" & i & "].Source"), "Prefix1", "Prefix2")
        Next i
        zFct.Start
        Set zFct = Nothing
    End If
    To use this Code, you have to create the Function "TestFunction" in the Editor as a PictureSwitch Function to the designatet Picture with substituted Variables (otherwise DynProperties("PictSwitch.SubstiVar[-1]") will show 0).
    881
    @mst: your code does modify existing linking rules (substitution) of variables before executing the function in the runtime (thats not creating a function in the editor)
    @rrkobra: if you have already a function available and you simply want to duplicate this kind of function you can make copy of the function itself and then modifing the parameters of the copied function to you needs
    Copy Functions:
    Manual -> Programming interfaces -> Object model -> RtFunction -> Copy
    regards,
    herbert
    10.08.2012
    17
    I would like to create the function in Editor from scratch.
    Br
    Lukasz
    10.12.2007
    260
    I know that my Code changes the substituted Variables from the Function in the RT, but I made the experience that this is much better than creating all the Functions via Wizard in the Editor.
    Reason:
    It doesnīt mind if you need more Functions later and it doesnīt matter if you change the Picture afterwards.
    But you are right, this is not exactly what rrkobra was asking for. (itīs better )
    881
    Somewhere on my harddisk i have a sample project which demonstrate the substition of variables within a screen switch function in the zenon runtime. the major advantage doing so is that you only have 1 function which you have to create and also maintain - before executing in the runtime the function is modified (as mentioned by mst).
    Let me know if you want to consider the above mentioned functionality of substituting variable of a function then i will search about this demo and upload it here....
    regards,
    herbert
    10.08.2012
    17
    So, it means that is not possible to do it in the editor with vba.
    Would be nice If you can upload your sample project.
    881
    -> of course it is possible
    Let me explain it via following example:
    If you create via zenon Editor (not VBA) a screen switch function and you do not make a subsitution there the function will not add the additional information (=DynProperties) - "Substivar".
    If you create via zenon Editor (not VBA) a screen switch function and you also do a variable substitution there it will add this information as dynamic properties (=DynProperties) to this function.
    With the VBA/VSTA method "CreateDynProperty" you can create those DynProperties "by hand".
    Check out the help documentation at
    Manual -> Programming interfaces -> Object model -> RtFunction -> CreateDynProperty
    for a code snippet
    Find in the attachment the mentioned sample project (see 2013-07-18_12-50-47 demo_replace_indices_vba.zip)
    Instead of wild card substitution the way via "replace indices" is shown. This has the advantage that the substitution is then also available for other functions which should use the same target
    It works at folowing
    in the zenon Editor
    - at the linked symbol 1 property is released (invisible button -> station name)
    - so on placing the linked symbol at the screen close the normal substition dialog
    - instead you double-click on the linked element and the integrated symbol wizard appears
    - here you enter the target (i.e. Motor1, Motor2, ... of course the variable structures with that name must exist)
    -> thats all you have to do in the editor (no further functions or so... )
    in the zenon Runtime
    - at this invisible button (at the symbol) also a "LeftClickDown" Macro is linked
    - on clicking this element the configured target (=station name) is read via VBA and then written to a string variable (shown at the top of the screen)
    - on release of the mouse button the linked screen switch function (also linked to this invisible button) is executed
    - this screenswitch function uses "replace indices" -> so it reads the value of the string variable (which value was before written via VBA) and then replaces all variables which matches the substiution criteria
    regards,
    herbert
  1. Create a function for a trend picture
    By robertf in forum VBA
    Last Post: 4th October 2018, 14:33
  2. linking multiple projects
    By talal.mubarak in forum zenon Service Engine Supervisor
    Last Post: 10th June 2013, 23:36
  3. Replies: 2
    Last Post: 12th April 2013, 14:40
  4. Zugriff auf die "Create PDF Function"
    By gralex in forum VBA
    Last Post: 17th March 2013, 23:17
  5. Execute function in VBA
    By focus in forum VBA
    Last Post: 17th January 2012, 15:17
