Thread: Minimal external variable change interval to be hooked in zenOn
    Default Minimal external variable change interval to be hooked in zenOn
    Hello, support team!
    We meet some new task - handle pulse signals in zenOn (do some actions by its front).
    Pulse minimum duration of 1 value while 0-1-0 changing can be close to 100 msec.
    When we try to hook such pulse front from math variables or using allocations with triggers we found that minimal interval time to hook should be more then 500 msec.
    Is there in zenOn some way to hook such pulses when interval of 1 value is less then 500 msec (close to 100 msec).
    Andrey
    Default Re: Minimal external variable change interval to be hooked in zenOn
    Hi Andrey,
    When you execute a function through e.g. a reaction matrix, even the shortest pulse should be captured.
  1. zenon logic doesn't communicate with external variables in zenon
  2. Navigator: Starzoom auf minimal setzen
    By alice18 in forum zenon Supervisor
    Last Post: 16th December 2008, 13:33
  3. Store variable data to file on change event
    By matholton in forum Drivers
    Last Post: 1st December 2008, 10:40
  4. Change variable status
    By brada in forum VBA
