Thread: About Webserver setting
    18.06.2013
    29
    Default About Webserver setting
    Hi Everybody,
    Am using zenon v7.00 I have installed zenon application and zenon webserver in same pc.Also configured in global_vars,js and host file .both zenon application and webserver are v7.00.when I open internet explorer in webserver am getting error attached in snap shot. Please guide me how to solve this problem.
    josefm Gast
    Default Re: About Webserver setting
    did the splash screen appeared? Have you installed the zenon Webclient too?
    Best regards
    18.06.2013
    29
    Hello Josefm
    Thanks for reply
    No. I have installed web client in another machine.
    I would like to know basic setting to do the connection between zenon web server
    and zenon web client.
    I have installed zenon application(editor& runtime) and Zenon webserver in same pc.
    I have created one project in zenon editor and open the runtime. I want to check in webserver so I have open (c:\intpub\configwwwroot\zenon\init.htm)with internet explorer it is not opening and showing page as I already attached.
    Default AW: About Webserver setting
    there is not much you need to do:
    In your constellation (Web Server + RT on one PC) you simply have to start your project (running as a network project with your PC as server) on this PC.
    Then you need to adapt the file:
    C:\inetpub\wwwroot\zenon\config\global_vars.js
    (Enter the project name, your PC as RT server and your PC as Web Server)
    Start the Web Server.
    On the Web Client PC simply navigate to
    //webservername/zenon/init.htm
    then your Web Client should start.
  1. Webserver Verbindungsfehler
    By rln in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 16th September 2014, 07:48
  2. Setting for Restoring PLC Value.
    Last Post: 9th September 2013, 00:09
  3. Variable setting
    By whitetaru in forum Drivers
    Last Post: 27th April 2011, 01:15
  4. WebServer starts in Demo-Mode at OS-Start although proper license is available
    By herberto in forum Smart Server & Smart Client (former Webserver & Webclient)
  5. Within the zenOn WebServer Console the buttons are greyed!
    By wolfgangm in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 13th August 2008, 10:34
