Thread: Note: 7.10 DVD Webclient "big setup" and zenadminsrv/zenlogsrv problem
    christian.hayna Gast
    Default Note: 7.10 DVD Webclient "big setup" and zenadminsrv/zenlogsrv problem
    Dear all.
    In the near past, it happened that the Webclient-Installation (big setup package) from the actual zenon 7.10 DVD doesn´t install the zenadminsrv or zenlogsrv services correctly. -> Therefore the Webclient does not start.
    (See also Article ID 195607 in the knowledge base on the service site)
    It is a sporadic problem, so it does not show up on every system. Still we understand it is very annoying.
    We already got a fix in the newer build version. (And i think, new Setup DVDs will be set up).
    So if you encounter this problem please ask your nearby COPA-DATA Support Team for the Webclient Installation Packages of Build 6571 or higher.
    29.07.2007
    Germany
    192
    Frage AW: Note: 7.10 DVD Webclient "big setup" and zenadminsrv/zenlogsrv problem
    same happens when installing the Web server!
    Is this issue also known and solved?
    H.-P.
  2. Alarmmeldeliste Filter "nicht quittiert" ODER "anstehend"
    Last Post: 31st July 2012, 15:20
  3. Replies: 5
  4. "prepare this blank disc" message when inserting 6.22 DVD
    By markclemens in forum Editor and Runtime Setup
    Last Post: 21st February 2008, 13:43
